700RWHP Cam Help
Old 12-04-2005, 12:35 PM
Forced370GTO's Avatar
Default 700RWHP Cam Help
i am about to install an iron 370 into my 04 gto along with a custom cam, supercharger, and intercooler. i will not be doing heads due to a lack of cash at the moment however i will eventually be installing patriot stage 3 heads. This is my daily driver and will be running anywhere from 12-14 psi. What type cam should i get for good power output and drivability? i would like something that sounds pretty mean but i dont want my car to feel like its going to shut off while idling. any help would be greatly appreciated, thanks.
Old 12-04-2005, 01:01 PM
white2001s10's Avatar
The theory with SC cams is that you can open the intake later and close it earlier. This leaves a relatively short intake duration.
Unlike a turbo that is very overlap sensitive, you can get away with more overlap with a SC.
If you have a good flowing exhaust valve/port and system, then the early exhaust opening isn't so important. The exhaust closing can be extended to well after TDC for some extra overlap.
The good thing about the overlap being on the ATDC side is that you get the powerful sound at idle, but yet the idle is strong. This certainly isn't important for power, but just a small plus.
You could pick a cam out yourself with these type of things in mind, but it's usually best to pay for a specific consult from an expert. Otherwise you may leave 100hp on the table and/or just not be happy with the results.
Sometimes people find that it takes 3 or more different tries at camshafts to get the one they really want.
Those are just my ideas FWIW
Old 12-04-2005, 01:18 PM
thankyou for the help!!
Old 12-05-2005, 12:01 AM
BlackHawk T/A's Avatar
Where did you get this info? For one you are generalizing with the term "SC". A Supercharger can be roots, centrifugal, etc...
If its Centrifugal you are talking about, its going to be the same thing as a Turbo. They both utilize centrifugal blowers, just one is spun off the crank and one is spun up by the force of the exhaust. Both force air into your engine at higher than atmospheric pressures so I don't see how they would be any different.
If I am wrong please correct me.
Old 12-05-2005, 07:24 AM
777's Avatar
Get the fm-9 from futral, it should work well for you.
Old 12-05-2005, 09:26 AM
PREDATOR-Z's Avatar
That is what I would run:
224/230 .581"/.592", 114lsa+1 (for your stock heads)
and bigger;
230/236 .592"/.602", 114lsa (for ported heads)
