Need advice from guys running this setup
Old 12-11-2005, 10:09 PM
just-a-z's Avatar
Default Need advice from guys running this setup
I want to upgrade my H/C and was wanting to get the most power out of my stock bottom end. My car will be at full weight (3650lbs) and on MT DR's or Nitto DR's with a 12 Bolt and 3.73's. I will also be running the 90/90 Fast setup and 36LBS injectors with ASP pulley. My car is an A4 and I will either go with an SS4000 or a PT4400. I would like to avoid flycutting the pistons or replaceing them if at all possible and I will run 100 octane fuel in the car. I aslo have an aftermarket fuel pump. Let me know what packages you guys in the 10's are running! I have pretty much been looking at 2 companies: AFR's 205's unmilled to avoid flycutting with a G5X4, or the Cartek 3x. Only bad thing with Cartek is the flycutting though. I am open to other companies as well though, so calling all the 10 second guys, HELP please.
Old 12-12-2005, 10:00 AM
just-a-z's Avatar
anybody in the 10's out there on a street car?
