205 AFR heads with 2.05 valve on stock 346 short block?
Old 12-15-2005, 07:01 PM
Abdullah's Avatar
Default 205 AFR heads with 2.05 valve on stock 346 short block?
will there be any intake 2.05 valve interference with the cylinder walls?
what is the maximum lift i can go with the stock pistons and short block without hitting the pistons?
thanks.
Old 12-15-2005, 08:53 PM
Beast96Z's Avatar
The 2.05 intake will be fine. People use them on stock short blocks all the time. As far as the max lift you can use, it all depends on the cam. LSA, ICL, and duration all play a huge part in wether or not a cam will clear. It's easier to ask if a certain camshaft, with full specs, will clear. At least then one can have an idea of what the cam is doing.
Old 12-15-2005, 09:38 PM
Abdullah's Avatar
how about a G5X-4 cam with the AFR 205 heads with 2.05/1.60 valves on stock 346 short block?
or i will need different pistons to clear?
Old 12-16-2005, 01:52 AM
Nittany_marine's Avatar
I have an X3 cam, and afr 205's. I had mine milled to 59cc's, so I had to flycut my pistons. Call up LG Motorsports, and they's be more than happy to help you out.
