ls1 making noise
Old 12-27-2005, 01:47 AM
flynlow3's Avatar
Default ls1 making noise
I wasnt sure where to post this so if its wrong please let me know. My car started making a whinning noise after i ran it hard the other night. Not redline but i got on it and ran it through the gears. When its not it gear, the whine increases with the rpms. I thought it was the transmission at first but having it do it in Neutral throws that out. Anyone have an educated guess as to how deep im in on this one? Any help is appreciated. Thanks in advance,
Jeff
Old 12-27-2005, 02:23 AM
2001FireBird's Avatar
Do you have stock gears? Or did you change them to say Motive? I've known some gear sets to have a sort of whining sound. Why you're only hearing this now, I dont know. But just a quick guess.
Old 12-27-2005, 02:38 AM
kindaslo's Avatar
Pilot bearing? Does it do it with clutch in and out, or only one way?
Old 12-28-2005, 01:21 PM
flynlow3's Avatar
It makes this sound no matter what. Its a 6spd and it does it when its not in gear too. I just hope its not a bearing in the engine.
Old 01-07-2006, 07:02 PM
Street Lethal's Avatar
Just curious, try disconnecting the alternator, and run the engine off of the battery only. I had an alternator go on me once after hard acceleration, and it gave the exact same "whine" throughout the RPM band. I doubt it's a bearing, unless you've been neglecting the engine of it's oil....
Old 01-07-2006, 08:04 PM
Rebelord's Avatar
or P/S pump....
Old 03-04-2006, 01:15 PM
flynlow3's Avatar
I keep my car mantained pretty meticulously. I think its actually the P/S pump like rebelord stated. I noticed it when i was turning through some sharp S curves the other day.
Thanks for your advice guys
Jeff
Old 03-04-2006, 02:31 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Richmond is the whining gear set.
Old 03-04-2006, 03:38 PM
flynlow3's Avatar
Havent touched the gears. Everything is OEM just as it was from the factory.
Old 03-07-2006, 08:14 PM
WiseguyZ28's Avatar
I'm havin a whining sound that sounds familiar also........it just started today. I went out to wash the car and wash off the engine bay. And everything went fine, engine was still cool.....washed it out....careful with the wires. I drove home like 1 minute away but left the car on to make sure the water would dry up, i used a leaf blower too. Turned the car on again, everything seemed fine....drove like 20-30 minutes and all of a sudden i hear a whining sound that gets higher with the RPM's....
Mine also does it whether its in gear or not...so i dont think its anything with the trans....i do think it could be somethin with the steering pump but wouldn't that whine only happen when i'm turning the wheel?
Old 03-09-2006, 12:08 PM
WiseguyZ28's Avatar
Well my whine went away....if anybody cares. Not really sure if it whined because i just washed the engine bay out an hour earlier or if it was somethin else....I dont know why it would whine an hour after i was done..and after 30 minutes of driving? But its gone and thats the good thing i guess.....hopefully it was just somethin wet.
