cam install price??
Old 01-10-2006, 10:23 PM
oreyk31's Avatar
Post cam install price??
i have a 2000 trans am ws6 and was wondering what is the going rate in GA preferably in canton area for a cam install and where to get it done at there is none around besides this CRAP hole in woodstock "North Georgia Speed Shop" just curious im pretty interested though!!! thanks
Oreyk31
Old 01-10-2006, 11:12 PM
JZ'sTA's Avatar
Typicially I would say between 450-750 is the going rate for just the labor.
Plus add in the cost of the cam, springs, timing chain, gaskets, etc.
Old 01-11-2006, 12:47 AM
SilverLS1's Avatar
JZ is right. Also, cheaper is not always better. You usually pay for what you get. The gurus in my neck of the woods usually charge 600 or so(more often). Pricey, but you know it will be done right!
Old 01-11-2006, 08:35 AM
Reject's Avatar
are they gonna tune it to i'm guessin yes?
Old 01-11-2006, 08:51 AM
oreyk31's Avatar
yes for the tune
oreyk31's Avatar
yes for the tune
oreyk31's Avatar
yes for the tune
Old 01-11-2006, 09:01 AM
Dixit's Avatar
oreyk31, there are a few shops in the area. RPMotorsports are fairly decent price and Lamar Walden Automotive in Doraville. I live in Canton right now as well. But I do all my own work.
Dixit
Old 01-11-2006, 10:24 AM
oreyk31's Avatar
where is the RPMotorsports located? are they closer than doaraville thanks for the info by the way. what is the biggest cam i can put in my car with out changing the heads?? and how big of a stall should i run with a Lunati -- Duration 224/224 - lift .560/.560 - LSA 112 and will that cam give me a mean lopping idle??
Old 01-11-2006, 10:43 AM
Dixit's Avatar
http://www.rpmotorsport.com/ located in Marietta.
Biggest cam without changing the heads, well you dont have to change heads to put a large cam, but you may have to flycut, but hard to tell. Dont know about stalls, Im a manual tranny guy.
That cam is not bad and the 112lsa will give it some good lope, but check with people who do them on autos, all I remember hearing and reading on big cams and autos dont go too well.
Dixit
Old 01-11-2006, 10:44 AM
GDM Z28's Avatar
my cam has about the same duration but my lift is a 585 and it lopes like crazy....you can tell the car is cammed. the specs you listed kinda sound like a z06 cam but i think a z06 cam has a little smaller lift. im sure someone else on here will know for sure.
Quick Reply: cam install price??
