Trick Flow Heads
Old 01-12-2006, 06:17 PM
Michael4034's Avatar
Default Trick Flow Heads
Anyone have any info on these? I see Summit now has them listed on their sight with a Jan 20th ship date. I assume the 13.5 degree would give a better PTV clerance for larger cams.
Old 01-13-2006, 01:39 AM
Jimmy P's Avatar
They are supposed to flow real good, prety similar to the ETP 215's. What was their price listed as?
Old 01-13-2006, 01:50 AM
SStrokerAce's Avatar
That would be "flow really well"
Not calling you ignorant but you should wouldn't want to "sound" that way.
And yes I am the grammar police, even though I'm not so wonderfull at it myself.
Trickflow lists the heads as:
.100 68 55
.200 142 115
.300 215 185
.400 260 230
.500 300 251
.600 320 259
Bret
Old 01-13-2006, 01:54 AM
42NightZ28's Avatar
.100 68 55
.200 142 115
.300 215 185
.400 260 230
.500 300 251
.600 320 259
Bret
Is this as cast or cnc?
Old 01-13-2006, 02:34 AM
mnc2886's Avatar
.100 68 55
.200 142 115
.300 215 185
.400 260 230
.500 300 251
.600 320 259
Bret
Not to call bull **** or anything, but those exhaust flow numbers are either a typo, or unreal. I don't see that being true.
Old 01-13-2006, 05:33 AM
vettenuts's Avatar
Where were they flowed?
What is the listed price?
Old 01-13-2006, 05:54 AM
pdd
pdd's Avatar
hopefully ill have a set soon
Old 01-13-2006, 08:38 AM
TAF Motorsports's Avatar
summit $2295 pair
$890 each - bare
cnc
Old 01-13-2006, 09:27 AM
rck329's Avatar
So, they're 13 degree heads. (13.5 actually).
I'm guessing they require a special valvetrain? Adjustable Jesels or something?
Old 01-13-2006, 01:10 PM
Thats what TFS lists in their catalog... don't kill the messenger.
Old 01-13-2006, 03:37 PM
DavidNJ's Avatar
Does trick flow have pics and info online?
Old 01-13-2006, 03:38 PM
Mike@TEA's Avatar
Here is what we know about that head. We have a prototype here and the flow numbers they advertise are accurate. The head is also designed to fit a 3.900" bore and uses stock rocker arms but will require a longer pushrod. There is alot of valve drop(more than the stock 5.7) with the 13.5 valve angle and the 2.040" valve, that's why they did it that way. The exhaust port seems a little on the big side, hence the big flow #'s but it only uses a 1.57" valve so it should still run very good we'll have to wait and see. They will all be cnc'd at 1st but they are working on an as cast version coming later in the year that should be pretty good too.
Old 01-13-2006, 04:50 PM
zupmanZ28's Avatar
Will you guys be selling them directly also? Any chance at getting a TEA worked trickflow head?
Eric
Old 01-13-2006, 06:48 PM
white2001s10's Avatar
it only uses a 1.57" valve so it should still run very good .
You mean run very well
Hey do you know if those exhaust numbers were with or without a pipe?
I've always liked the old TFS head for the sbc. They were sometimes a PITA to work with to get everything right, but always performed very well.
Old 01-13-2006, 07:45 PM
JZ'sTA's Avatar
Originally Posted by white2001s10
You mean run very well .
HAHAHAHAHAHA That was pretty funny.
[/QUOTE]
[/QUOTE]
Those numbers are defentially with a pipe.
Probally a large pipe that is very short and extreemly straight.
Maybe 10" long...??????
Old 01-13-2006, 11:06 PM
P Mack's Avatar
What happened to your afr setup?
Old 01-14-2006, 12:02 AM
JZ'sTA's Avatar
He probally either got smart real quick or got real tired of waiting for the damn AFR's.
Old 01-14-2006, 02:54 PM
Thanks for your replies. Does anyone have info on push rod length and avaliability? Also any idea of PTV on a G5X2ish cam on a 112lsa?
Old 01-14-2006, 03:37 PM
Ed Curtis's Avatar
Talking
Old 01-14-2006, 05:14 PM
pdd
pdd's Avatar
LONG STORY
