clutch disc flywheel alignment issue (pics)
yea so check out this top notch machine work....
Anyone think this will cause major problems if i say f--- it and try to use it? You can clearly see there is about 1/4 of friction material not touching the flywheel surface whatsoever... How stupid is that... Guy from egay wont do anything about a refund...
LS1TECH Sponsor
clutch disk
That is the wrong diameter disk for that flywheel. Measure the diameter of the friction surface on the flywheel, then order a disk to match. Looks like you have a ten or 10.4 inch disk with an eleven inch flywheel.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
its a SPEC 3 carbon fiber clutch disc/pressure plate. I didnt know there were different sizes for LS1 clutch/flywheels. I thought they were all the same.
I should just sell all that **** and get a twin disc anyhow...
