Which cylinder head would you use with this setup
Ok I am going to be useing the thunder racing cheater cam and can't afford the AFRs. It seems like patriot performance heads are more in my price range. I am just not sure if i should go with there ls1, ls6 or the 5.3L heads.
I obviously want whichever will make the most power. But i don't want any problems with valve clearance or anything else. What would you do if it were you. If there is other heads that will work better that are in the 1200 range ler me know. I will be useing stock exhaust manifolds and cats.
Know for the specs on the cam
215.9/231.4 duration .604/.584 lift LSA 116.9
LS6 Heads
Lift 2.02" Intake 1.57" Exhaust
.100 72 cfm 65 cfm
.200 140 cfm 124 cfm
.300 202 cfm 160 cfm
.400 244 cfm 196 cfm
.500 280 cfm 220 cfm
.550 291 cfm 226 cfm
.600 304 cfm 229 cfm
LS1
.100 67 cfm 61 cfm
.200 133 cfm 108 cfm
.300 194 cfm 147 cfm
.400 242 cfm 183 cfm
.500 274 cfm 205 cfm
.550 290 cfm 213 cfm
.600 296 cfm 220 cfm
LS6 Heads
.100 72 cfm 65 cfm
LS1
.100 67 cfm 61 cfm
you might also want to look at the new gen TEA stage 1 heads and their flow numbers or even give them a call their heads are better than PP and the same price. Nothing wrong with PP though. I after thinking more about it think the TEA stage one heads utilizing the stock valve sizes and they flow a shitload just as much as heads with larger valves installed would be a great choice to go with because of the high velocity of the airflow. Definetly call up TEA and talk with them about their new port program and their stage one head.
Originally Posted by camarokid94
could but i called and intake runner size they said was in the 235 rnage and there CNC dart heads in the 237 range thats huge i think.
PP LS2 243's are 227 intake 80 exht.
LS1 Tech Administrator
The answer is obvious, but not easy to find. Get the highest flowing head with the smallest cross-sectional area in the port, with the smallest cc chamber you can afford. A nicely ported 5.3L head is usually the way to go as so many of the ported LS6 heads have HUGE cross-sectional areas and low velocity at low rpm. A PRC 5.3 or a TEA 5.3 would probably meet all these criteria with your budget.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I was thinking about the 5.3L but wasn't sure if i would run into any Piston to Valve issues. Whats the lowest cc i could get with out issues. I would like to run as much compression as possible on 93 octane with stock engine.
I don't think you will run into any PtV issues with the PRC 5.3s, but call someone like Jason, Trevor or Joseph @ TSP and they will help you out and figure out what is best for your setup. That should work well with that cam.
i was looking at the PRC 5.3 and was wondering which one would be best for me. they have a stage 1.5, 2.5r, 2.5s. Theres not a very big price diffrence only a few hundred dollars. I am willing to sacrifice some low end for more highend if it will make the car run a quicker et. I am putting a 9in rear in with 3.7 gears and a locker. So i will be launching the car at a reasonable rpm with DR. Will the heads i choose make a diffrence on emissions? The cheater came is supposed to pass emissions and i need it to.
Thanks for all the help everyone.
whats up with TEA saying their new port program on their ls1 head outflows their 5.3 head? Does anyone know the reasoning behind that? Is it just a comparison of their new port program against their old port program or was their 5.3 head ported using the same program?
Oh and back to my original recommendation I would go with the PRC cnc ported Dart heads for only 1500 bucks that looks like the best deal around. Those are aftermarket cast heads it might be worth spending the little extra for the aftermarket castings.
Originally Posted by STRIPSTAR
Um, if your in philly they dont do emissions anymore so it doesnt matter.
Really, do they just scan the computer for codes, becaues last year i failed because i disconected my battery when i was installing my radio and amps and didn't drive it long enough to reset the computer or something like that. Ended up costing me $180.
