where to mount oil temp sensor?drill?
Moderator
Believe that little cast piece, is where the trucks put the oil
cooler hard lines. Presuming you care enough to watch it,
maybe you want to manage it as well and then your options
for sensor plumbing expand.
Originally Posted by Teutonic Speedracer
You can tap into the little cast piece by the oil filter. The C5's are pre-drilled and tapped with a sensor already in place. I think the little cast piece is held in with two bolts.
