02+ z06 cam install quetion, need ur help!
i just got a 02+z06 cam w/ the ls6 valve springs. is that all i need to do a swap? or do i need to upgrade to titanium retainers and upgrade the pushrods? need your help!!
Lengths
99.9% of people upgrade pushrods no matter what cam they get, but the Z06 cam has a smaller base circle to offset the longer Z06 LS6 valves. So a slightly longer pushrod would align valvetrain geometry correctly. Although, a lot of people will say they use the stock 7.400" rods with no problems.
Originally Posted by PREDATOR-Z
If you are doing:
LS6 heads/valves + LS6 cam > stock or 7.40 aftermarket
LS6 heads/valves + Ls1 cam > 7.375 aftermarket
LS1 heads/valves + LS6 cam > 7.425 aftermarket
