Rollmaster Double and Powerbond/SLP UD Pulley
Old 02-03-2006, 08:36 PM
Greg_E's Avatar
Default Rollmaster Double and Powerbond/SLP UD Pulley
Does anyone know if the Powerbond or SLP underdrive pulley will fit without modification when using the Rollmaster double roller timing set?
Also, are all ASP pulleys machined to work with the double roller chains? I have conflicting info from two vendors. One told me they still have clearance issues and have to be machined to work with the double roller, and the other said they buy them from ASP machined to work with the double roller. Thanks.
Old 02-03-2006, 09:38 PM
Beast96Z's Avatar
I had th erollmaster/powerbond set-up on my 383 and had no issues. From what I gathered, only the old ASP pulley's had the clearence problem. Once ASP found out about it, they started machining all the pulleys to clear. There was a particular date stamped on the ASP's, but I can't remeber it. Sometime back in 03' is when the new machining started.
Old 02-03-2006, 09:56 PM
2scoot's Avatar
Hes right on. I just installed a Rollmaster and Powerbond with no issues. Word to the wise....use an ARP bolt with red locktite. Set it and forget it.
Old 02-04-2006, 08:04 AM
Greg_E's Avatar
Thanks guys!
