i need an answer
i need an answer
anyone know how much lift you can squeeze into a ls1 with the heads milled .030 before you have piston to valve problems i have a cam with that is 234 242 598 609 on a 114 and my heads are milled .030 thought i might throw it in for a test thanks Scott
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, the only real way to tell is if you can clay and do the math on it. I would have to say just from your post on here that it would probably not clear. Just based on the looks of what the valve events are gonna be. you never know till you try though. But seriously...Try the clay method and see what you come up with. There are several good write-ups on it.
