What big cams are available when using ETP 11* heads while not having to flycut?
This post may be good for use as a sticky as there are many of us that are looking at etp heads for extra PTVc.
I have been looking and watching for posts regarding the use of the 11* heads and big cams on stock LS1 motors without flycutting. I am still seeing information being construed by others as to which cams will fit and those that won't without flycutting.
I plan to call TSP later next week to see what they have to say. I have seen that they are selling the ETP heads (I may have missed it) but have yet to see em post anything about selling em. I was hoping to make use of one of TSPs big cams and taking advantage of the 11* design. Maybe it is too early to be asking questions. Because of the lucky few that own em, I am hoping that some may already have the answers I, as well as others, are looking for.
Finally, with wanting to keep with the stock bore and bottom end theme, what size runners should I look into? Should I stick with 215 or look at the 225 or reach to the 240? I have heard more then once that the 240 isn't overkill (is this correct?).
Semper Fi,
Rob
Semper Fi,
Rob
The ET Heads (the 215's in our particular case) have better P/V clearance than stock even with substantial milling. Depending on what you are trying to accomplish a TRex or similar sized cam will fit with no issues whatsoever.
I just finished putting a set of 215 on, I got from Thunder. Geoff suggested the Trak cam.I have plenty of ptv clearance, just got my push rods in 8.100. All that is left is the intake. After Geoff is done tuning it I well post some dyno numbers.
Please guys, quit picking the biggest cam that will fit under a head in search of a good setup. Its not going to work. Whatever cam was the pimp cam for stock heads, is NOT going to work the best with these heads, we can assure you.
Youll be much happier if you pick the head that suits what your doing then cam according.
Weve had some of these on the flowbench, and while they flow alot more then the stuff guys are used to workign with, they arent going to make the power if you dont make good cam choices
As I agree with your suggestion of not using the trex (which at the time wouldn't fit in most aftermarket heads) with aftermarket heads I don't see any reason you should disagree with the fact that the G5X3 112 or any of the big TSP cams would make a great choice. I remember back 5 years ago when many thought that the 231-237 was too large a cam. With some experimenting, and the use of these heads, maybe the LS1 can hit 500 with alittle streetability.
Semper Fi,
Originally Posted by BAIN
How much milling are we talking about? How much compression?
ETP says they can go just about anywhere with it. I was thinking maybe 59cc? I'm still picking up more info on these heads.
Semper Fi,
Semper Fi,
Semper Fi,
No those cams will not make very good choices for these heads from what weve seen. Hit me with an email if youd like.
Just how many ETP combos have you seen on bolt-on 346 cars? Any and all info you have please by all means please post it. There are many of us that are looking for options but since these heads are still new the info isn't there to browse hence my comment about making this a sticky.
Semper Fi,
Originally Posted by 02ZOh6
Checking in. I just ordered mine and am looking for a suitable cam also. A&A made 470rwhp with a 228/232 cam and a Fast 90/90.
Was that using the 11* heads?
Semper Fi,
Semper Fi,
We should be firing up a ETP stock bottom end car this week, weve had some of their heads for a few months now
Been very busy in the shop. We are ETP dealers, and we are doing some testing on a stock bottom end car to see what she likes best. Mainly the point Im trying to make is dont pick the best cam that works with stock heads for example, because they are far from stock heads
Selling these heads, we dont want customers to buy some heads, then order up random XYZ cam from somewhere, and cross their fingers hoping they will work well together because 9 out of 10 it wont
We have already tried a cam of similiar duration to the G5X3 or Magic Stick that didnt clear w/o flycuts. Little more aggressive though
