queston for 408 guys
i was wondering what kind of horsepower i would be getting with the set up i have picked out i am shooting for the 500rwhp range and was just curious if some of you guys might be able to give me a ball park on this 408 setup
stage 3 6.0 L heads
244/248 cam with 110 lsa at .6** lift
fast intake 90/90 setup
facrory rocker arms
comp 850-165 lifters
42# injectors
longtubes
t56 to moser twelve bolt
its a basic list i didnt want to type out all the details
stage 3 6.0 L heads
facrory rocker arms
42# injectors
longtubes
stage 3 6.0 L heads
facrory rocker arms
42# injectors
longtubes
stage 3 6.0 L heads
facrory rocker arms
42# injectors
longtubes
what heads EXACTLY are you talking about "stg 3" means nothing. and what headers are you talking about getting......cant give a good estimate with out all the facts.
2.08 intake 1.60 exhaust valves
PCR SPRINGS
2033 CC INTAKE RUNNER
88CC EXHAUST RUNER
315-320 PEAK FLOW INTAKE
247 PEAK FLOW EXHAUST
PCR SPRINGS
88CC EXHAUST RUNER
even with a set of 1 3/4 headers, you should be at and over 500rwhp. You can build the badest longblock all you want. Be perfect on all of your tolerances, specs, so on.
But your cam is what's going to determine how that motor will work together. I think you should be fine, actually your combo is very near to mine, it was built a year and almost a half ago and i have a twin with the same combo, but through a m6 and he makes 538rwhp, 470 rwtrq.
Your heads are from ETP...well, we have alot more in common!!
Good luck, you'll be fine..dont worry to much on the numbers, just get your driving technique becuz you'll need to relearn how to drive it.
