Comp cam card question
Old 02-20-2006, 11:16 AM
GuitsBoy's Avatar
Default Comp cam card question
im not sure what advance this cam has ground into it. The card does not say. However the instructions say that most comp cams are ground with 4 degrees advance. the cam is on a 112 ls1. The cam card has a disclaimer that reads something like: *specs if installed on a 110 ICL. Now 112 - 110 = +2. Its the if part that throws me. does that mean that theres +2 ground in or is it the usual +4 since it dosnt directly say...
cam in question is a 232/234 .595/.598 112
Thanks
Old 02-20-2006, 12:35 PM
triumphman's Avatar
Look at the intake lobe if the centerline is 108 then it has 4 degrees advance built in.
Old 02-20-2006, 12:39 PM
GuitsBoy's Avatar
it dosnt state the ICL on the card.
Old 02-20-2006, 12:41 PM
SideStep's Avatar
I have had this problem before. Just call CompCams and give them the serial... they will have all the details on file...
Old 02-20-2006, 03:36 PM
GuitsBoy's Avatar
Cool, called them up. The cam was indeed on a 110 ICL. +2 advance it is.
