ET LS7 Style Heads.
6 Second Club Moderator
ET LS7 Style Heads.
Does ANYONE have a rocker system or pedestal that will work with a stock LS7 rocker????? I have a set of ET LS7 style heads but can't use them until I get a set of rockers that will work with them!!!!!!!
Originally Posted by Nasty N8
Stock LS7 rockers work or we are having Harland Sharp build a set. Soon to come.
Nate
Nate
Let me know APSP!! 630-782-6000. BTW,. the stock LS7 rockers won't work without a custom pedestal.
Originally Posted by Beast96Z
Et is probablly going to be the only place you can get the pedestals.
That's not what I wanted to hear. I'm sure Jesel will make them when they get a set to mock up. I know ET will make something, I just need something now.
Originally Posted by Ls1Joe
Jesel has rocker arms, but I believe the rocker stands on the heads have to be machined. I saw the rockers at the PRI show in December.
Andy,
With the stands, which you have, the Factory LS7 Rocker arms will work. If you need a fully adjustable set then right now Jesel is finishing them up. They are different valve spacing than a factory LS7 head. BTW the fuel rails I think may be done for the LS7, I just have to check to see if he has them yet. Is the number still the same?
Thank you,
Craig
Thank you,
Craig
Originally Posted by Craig@ETPerformance
Andy,
Thank you,
Craig
Thank you,
Craig
