internal engine guys couldn't help me with this one!
alright lets see how the advanced area does alright on the maincaps...the bolts that go threw the sides of the block. i have 6 long ones and 4 shorter ones. i measured the holes, they all appear the same depth. anyone know the proper positions for these bolts or should they all be the same length and some how the cam cover bolts got mixed up or something? thanks.
ummm, did you do a cam swap by any chance? Because if you did, you may want to check the cam retainer bolts. If you used the long ones, you may have clearance problems with the cam lobe and the bolt!!!!!
