i hope this isnt the dumbest question in the world
Old 03-03-2006, 11:29 PM
camaroextra's Avatar
Default i hope this isnt the dumbest question in the world
are combustion chambers factored into the displacement of an engine?
i was just wondering because 1ci = 16.39cc right,
64cc combustion chamber X 8cylinders / 16.39 = 31.25ci!
or do i suck at math and need to put my calculator away and go to bed?
Old 03-03-2006, 11:39 PM
Grimes's Avatar
looks okay to me. what's the prob?
Old 03-03-2006, 11:50 PM
P Mack's Avatar
No, combustion chamber size is not a part of displacement. Displacement only has to do with the amount of volume the pistons move through (area x distance). One way to think of it is if you fill the cylinder with water at bottom dead center, and move the piston up to top dead center, the amount of water that pours out is the displacement of that cylinder.
Old 03-04-2006, 01:41 AM
Grimes's Avatar
mack is correct, but why, are you suprised that the combustion chambers "add" so much volume?
Old 03-04-2006, 02:29 AM
heavymetals's Avatar
Doesn't:
displacement/chamber area=compression ratio?
Old 03-04-2006, 06:08 AM
Gm-LSX's Avatar
Originally Posted by heavymetals
Doesn't:
Right. Includes Addition/Subtraction of Gaskest Diameter, copressed Hight and Piston Dome/Rlief (Stayin/Stayout)
