Cam question- required seals,gaskets etc
Planning on picking up my f13 from futral soon and i was wondering if this package they offer is required?
"2 GM Valve Cover Gaskets, 2 GM Water Pump Gaskets, GM Crank Bolt, GM Timing Cover Seal, GM Timing Cover Gasket"
could i just use my existing seals, gaskets etc?
I just did my swap and the only gasket I really needed was the water pump ones because my car is a 98. The rest of my gaskets looked exactly like the new ones. I changed them anyhow since I had paid for them. I also used a new crank bolt.
