Has anyone seen results w/RHS or edelbrock heads?
Still researching a H/C package, think I will go w/Dart 225 and futral cam(f15?).
Just wondering if anyone has seen results on the Edelbrock or RHS heads?
Just want to know whats out there-What do you guys think?
why would you choose a futral f15 cam to run with some ported Dart heads? that cam was developed to be run with stock cubes and stock heads. why not have a custom grind made that is more suited for your new heads and motor setup. by having the Gen 7 your tuning should be a brease and no issue at all. i'm wondering why you would run a DFI on just a heads/cam motor myself but to each his own. the F15 cam with those heads and a 6.0 will leave a LOT to be desired.
The DFI was already in the car when I was running the 383 SBC.
I did not realize that cam was designed for stock headed vehicles. I planned on calling Futral and figuring out a nice package.
By the way have you seen Kraest's vette. His combo uses out of the box dart 225 milled .020, and futral cam (I believe f-15)-470 RWHP. I am looking to make power in this range-more if possible.
what kind of CI is Kraest running? just because someone had decent results with s a particular setup that doesn't mean that you can't make more with a better suited cam. give SIMPLEQUICK RACING a call, they're a sponsor on here, he has a TON of experience with LS1 cams and has been doing it since 98 when these bad boys came out so he has the knowledge.
simplequick racing? I will check them out.
i've delt with them, several moderators on the site have delt with them (Brandon, Cyphur Trac, etc...) SQR has been dealing with the LS1 stuff as long as or longer than any shop sponsoring this site. very good guys over there.
lt1dave made over 500rwhp through a 9" with some patriot heads and custom cam in a stock lq9 short block. only mods are katech rod bolts. Might want to contact him for one of his packages
