Making ticking noise.
My car is making a ticking noise, someone told me that it was probably piston slap but it sounds to me to be a valve or up in that area. It doesnt do it all the time it does it more than it doesnt do it though. It used to not be that bad but it has gotten that it does it all the time or like I said more so than it did. it hasnt gotten louder or anything like that just doing it alot more. Just worried about it and if their is anything I could do without breaking the motor down.Or do I need to start thing on that. Also was thinking about doing a cam job but it was gonna be further down the road. Any ideas or advice would be greatly appreciated thanks in advance.
Yea my runs strong going to take it to the track this weekend for the first time and see what she will turn out. but still conserned would like to get it stopped I'm runing 10w40 senthetic. Thought that might make a diffrence but nothing.
Well, I'm here to tell ya, I lived with a damn tick for three years and I finally fixed it with a new set of lifters. I had to replace them myself because the dealer said it was normal. That's not to say it will work for you, but you never know until you try. BTW, I replaced the stockers with Mellings I got from Futral. $165.00 for the set! Excellent!
It could also be a bent pushrod, in which case the solution would be pretty easy. Just pull of the coil packs, then take off the valve covers. Next you wanna take off the rockers and check each individual pushrod. If one is bent, replace it...obviously. If none are broken that it may be a valve as someone said. I would check your plus first though. Good luck!!
