Stock Flow of 2002 241s?
Originally Posted by Gunnar@Patriot
The stock LS1 heads we have flow tested here are in the high 220's to low 230's @.600".
Originally Posted by 98camaroLS1M6
That LS1, is that a 2002 head only flow 228? Doesn't look right.
What have you heard?
Here is a link to a thread where we posted some stock 241 flow numbers.
https://ls1tech.com/forums/generation-iii-internal-engine/434099-what-does-stock-ls1-head-flow.html
Just for kicks, here is a link to some stock 243 heads we flow tested.
https://ls1tech.com/forums/generation-iii-internal-engine/434815-what-do-cast-ls6-heads-flow.html
Both this and the stock 241 flow numbers are from our Superflow 1020 bench, using a 3.905" bore, and a clay radius inlet.
