h/c question
h/c question
Hello all, I'm sort of new but have been researching this board for a while. I am planning an ls1 swap in my 90 camaro. I originally wanted a afr headed, fast 90/90, trex cammed 346 ls1, but through my searching have come up with a couple of questions. I will probably be using a 6 speed and 3.73's, maybe 4.10's, for my setup. I will auto cross this car and also take it to the strip. It will also be my daily driver. I was hoping for a 11.5 car with 3000 race weight. I know afr's are pretty much the best you can buy, but i was thinking maybe darts will get me more of what i'm lookng for. Also, will the ms3 be a better dd and better for autocrossing as the powerband on the trex is pretty elevated? I will probably still use the fast intake but maybe a new tb. What do you guys suggest for the tb and maf. I was thinking porting a z06 maf and getting the holley tb. What do you guys suggest for 500 rwhp.
you can go 11.5's at 3000lbs with a mild cam only car (228 duration), 4.10s and a set of slicks. You probably aren't getting many responses because this type of question gets asked fairly often and the answers are searchable.
I would say a milder cam with solid midrange torque would be better for you application. 224/224 .581?
