LS2 Timing Chain Slack OK?
Old 04-13-2006, 02:46 PM
JoeMack's Avatar
Default LS2 Timing Chain Slack OK?
Just installed my new cam, new LS2 timing chain and noticed that there seems to be quite a bit of slack in the chain. Is this normal? Thanks
Old 04-13-2006, 03:25 PM
UltraZLS1's Avatar
Maybe your gears are too worn?
how do the teeth look on them?
I just bought an ls2 chain and have never heard of this problem....here we go again ...another issue
Old 04-13-2006, 03:26 PM
hotrodrx7's Avatar
https://ls1tech.com/forums/showthrea...ng+chain+slack
Old 04-13-2006, 08:14 PM
JoeMack's Avatar
The teeth look fine. The car has only 19K miles on it. Not really sure if it is a problem or just normal.
Old 04-15-2006, 10:02 AM
JoeMack's Avatar
So then it is safe to assume that the slack is normal? Thanks
Old 04-15-2006, 10:05 AM
gollum's Avatar
Measure your slack at its most loose point and give us the figure.
Old 04-15-2006, 12:00 PM
JoeMack's Avatar
This is without any lifters installed. I kept tension on the cam gear to where there is only slack on one side of the chain. It looks like a little less then a 1/4" maybe 3/16" (hard to tell) of slack.
Old 04-15-2006, 12:04 PM
gollum's Avatar
Thats about right. Your OK
Old 04-15-2006, 12:34 PM
moeZ28's Avatar
according to comp cams tech line, 1/4" to 1/2" of play is within specs and is okay. i called about a double roller b/c i thought i had too much slack on mine. but they said its fine.
Old 04-15-2006, 09:52 PM
JoeMack's Avatar
Sweet. One less thing to worry about. Thanks everyone
Old 04-15-2006, 10:58 PM
Redneck Z's Avatar
I noticed this when I put my LS2 chain on, but it seems to be normal.
Quick Reply: LS2 Timing Chain Slack OK?
