Need Advice with Crane Cams 1.7 Gold Rockers
Im in the later stages of my Cam swap, and Im just about to toss these on. My question is this: in the Crane instructions, it shows where you should notch the valve covers for the perimeter bolt valver covers. Obviously I have Center Bolt ones. Im just curious if Im going to have to modify the valve cover at all (ie. notching, or spacers) to get them to fit? I'd assume not since the only "notching" you had to do on the perimeter bolt ones were where the bolt holes were thicker.
Also, any suggestions concerning the kit I should be aware of before I toss them on? Thanks!
