402 and ls1 heads
Old Apr 16, 2006 | 06:06 AM
hulk's Avatar
Default 402 and ls1 heads
can i use ls1 stock heads for 402 cid and ls1 stock cam
and witch gaskets
Old Apr 16, 2006 | 07:04 AM
Hemi Killer's Avatar
14 Second Truck Club
Why do you want to do that?
Old Apr 16, 2006 | 07:26 AM
92zcamaroperson's Avatar
that would really cripple an otherwise powerfull motor.
Old Apr 16, 2006 | 07:50 AM
gollum's Avatar
It has been done but with a cam change also.
Look here!https://ls1tech.com/forums/dynamometer-results-comparisons/462218-stock-headed-408-468-460-w-ls6-pacesetters.html
Old Apr 16, 2006 | 08:26 AM
beardWS6's Avatar
Would never do that. Why build it and then under man it?
Old Apr 16, 2006 | 08:44 AM
CashMoney's Avatar
+1 if you have to save for better heads.
Old Apr 16, 2006 | 08:48 AM
DrkPhx's Avatar
Then you should continue to save your money for the right cam, heads and intake building the motor on the side. You have to also consider you need to upgrade your drivetrain and fuel system as well. Strokers aren't cheap, don't skimp and do it right the first time.
Old Apr 17, 2006 | 02:16 AM
hulk's Avatar
im waitting for afrs for 8 months
Old Apr 17, 2006 | 05:06 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would keep saving.
