Stock Headed 408 - 468/460 w/ LS6 and Pacesetters
Old 03-02-2006, 01:48 AM
Brandon Boomhauer's Avatar
Default Stock Headed 408 - 468/460 w/ LS6 and Pacesetters
I guess being the moderator of this section I should post up my numbers.
A big thanks goes out to Daniel/Scott/Joe of SimplequickRacing for making this work for me. The car drives like a baby cam car and pulls like hell through all gears. I can put around at 1300rpm in 6th no problem.
408 Built by Erik @ HPE
8cc dish Weisco's
Stock 241 heads
10.96:1 Comp.
244/248 612/615 on 115 XE-R Lobe
Though an M6
LS6 Intake
Home Ported TB
Pacesetter Headers
True Duals
SD Tuning by SimplequickRacing
Put 468.8/460.8 down with somewhere near 300 on the clock.
The graph I have a picture of currently is a few shy of that.
Old 03-02-2006, 02:41 AM
prostock_bigblock's Avatar
solid numbers , congrats considering thw baby cam and stock 241 heads , thats amazing.
347fairless's Avatar
Wow!
Old 03-02-2006, 03:02 AM
DocEwww's Avatar
What are those numbers converted to SAE? Not really familiar with STD correction factors...
Amazing numbers for stock 241s
Old 03-02-2006, 03:09 AM
'99slobird's Avatar
Sounds like a winner to me! Congratulations!
Old 03-02-2006, 07:53 AM
408LS1TA's Avatar
Awesome numbers! That torque "curve" is phenomonal! Especially for a stock untouched set of heads. I've got a 408 with that same cam from HPE... and mine's not making 400 ft.lb til 4k! Hmmmmmmmmmmmm.
Old 03-02-2006, 09:26 AM
Ravenous T\A's Avatar
thank-god I feel better about my cam now Good numbers, I should have sprayed ya
Old 03-02-2006, 10:25 AM
bad95killer's Avatar
Stout #'s with stock heads & that cam....Congrats man
Damn how i like FLAT TORQUE CURVES
peace
Old 03-02-2006, 11:33 AM
waSStock's Avatar
From the Land & Sea Dynomite Dynamometer Help File...(DYNO-MAX 2000 Pro Software)
Observed – No atmospheric correction is applied.
Standard – Atmospheric correction is applied using the SAE’s J607 "STP" curves, based on: "60 degrees Fahrenheit Inlet Air temperature, 29.92 inches of Mercury barometric pressure @ at 32F (101.32 kilopascals), and Dry Air."
This atmospheric correction takes Mechanical Efficiency into account based on either the SAE’s simple Fixed 85% ME or (optionally) by utilizing DYNO-MAX 2000’s more sophisticated Friction Compensation algorithms for estimating the ME%.
SAE - Atmospheric correction is applied using the more conservative (than Standard) SAE J1349 correction curves, based on: "77 degrees Fahrenheit Inlet Air temperature, 99 kilopascals (29.38 inches of Mercury barometric pressure @ 32F), and Dry Air."
DIN - Atmospheric correction is applied using the DIN (German) correction curves, based on: "68 degrees Fahrenheit Inlet Air temperature, 101.32 kilopascals (29.92 inches of Mercury barometric pressure @ 32F), and Dry Air."
This atmospheric correction does not take Mechanical Efficiency into account.
J1995 - Atmospheric correction is applied using the SAE J1995 (diesel) correction curves, based on: "77 degrees Fahrenheit Inlet Air temperature, 100 kilopascals (29.53 inches of Mercury barometric pressure @ 32F), and Dry Air."
JIS - Atmospheric correction is applied using the JIS (Japanese) correction curves, based on: "77 degrees Fahrenheit Inlet Air temperature, 99 kilopascals (29.38 inches of Mercury barometric pressure @ 32F), and Dry Air."
This atmospheric correction method uses exponential curves rather than the Mechanical Efficiency factors.
ECE - Atmospheric correction is applied using the ECE (European) correction curves, based on: "77 degrees Fahrenheit Inlet Air temperature, 99 kilopascals (29.38 inches of Mercury barometric pressure @ 32F), and Dry Air."
DYNO-MAX 2000 Help - Copyright ©2005 - All rights reserved. Land & Sea, Inc.
Old 03-02-2006, 07:26 PM
Louis's Avatar
Brandon, cmon, you should know ! SAE#s !!!
Old 03-02-2006, 08:37 PM
BADFNZ's Avatar
By the look of the conditions on the bottom of the sheet, it looks like the SAE numbers should be higher. I'm pretty sure that 1.06 is the correction factor.
Old 03-02-2006, 08:41 PM
eric01ss's Avatar
nice numbers brandon i would like to see your car with a fast 90/90 setup and good heads with some kooks 1 7/8 headers it would be freaking sweet!
Old 03-02-2006, 09:31 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Very nice numbers. Congrats!!
Yeah Erik is definitely one of the best.
Old 03-02-2006, 09:54 PM
I have SAE numbers somewhere, I'll get them from the shop next time I'm down there.
I really dont think it was morethan a few hp difference, and SAE might have infact been higher.
uncorrected, even in the hot *** august temps was higher too...
Old 03-02-2006, 10:16 PM
jrp
SN95 Director
jrp's Avatar
when the **** did you get a 408
Old 03-02-2006, 11:35 PM
z06matt's Avatar
I believe August of 05... it was just on the down low.
Great numbers Brandon...
Old 03-03-2006, 06:40 PM
LC
LC's Avatar
sorry for the ignorance.. but.. Stock heads? like the stock heads of a 98/02 LS1?
Old 03-30-2006, 08:46 AM
back from the dead.....
but yes luis completely stock untouched 241 heads.
Old 04-01-2006, 09:58 AM
Shorty Director
VINCE's Avatar
Congrats on the #'s!!!
Old 04-02-2006, 04:35 AM
verbs's Avatar
STD is usually 4% higher than SAE....so SAE you'd have about 450rwhp/445rwtq.
Quick Reply: Stock Headed 408 - 468/460 w/ LS6 and Pacesetters
