Valvespring Compressed and Stuck!
I'm having problem with my ls1 in my rx7. The rocker on the intake side on piston 1 broke and dumped needle bearings all over the place. I installed a set of harland sharp 1.7 rockers today. I rotate the engine and see that the rocker on the intake side on piston 1 is not moving at all. The spring is staying in the compressed position; all the other rockers work normally.
Any ideas? I don't want to remove the heads.
When the rocker failed it could have screwed up the geometry enough so that the valve stem got bent.
That would explain the stuck valve.
The only way to tell is to remove the rocker.
There is no way that I can see one of the bearings jamming up the works good enough to hold a valve stuck under spring pressure.
Good luck
Good luck
If someone offers my asking price, I'm going to have to sell it.
https://ls1tech.com/forums/vehicles-sale-lsx-powered-only/492355-fs-ls1-1994-mazda-rx7.html
