How do you know if I have a blown head gasket?
Symptoms are:
1. burning a lot of oil
2. going through a ton of radiator fluid, car got hot once but I pulled over and she cooled down quickly
is this a head gasket issue, or something else?
what can cause a blown head gasket anyway?
(I have sprayed a 200 shot about 3-4 times, but car is properly tuned with good a/f)
No signs of any leaks around the heads?? No white smoke? If your burning a ton of coolant it is most likely a head gasket. If you arent sure look at your plugs and do some compression testing... do not drive.
I've seen blown head gaskets from people overdrivng nos applications.
How to tell if you have a blown head gasket!
Here is a great link on how to tell if you have a blown head gasket and also how to prevent one!
http://freecarsupport.com/blog/2012/...t#.UIsqSWk-t7Q
