Trick Flow heads in the 10s!
Moderator
I went to the track (Montgomery Motorsports Park) last night (Friday 7/7/06) and ran the following with the new TEA Trick Flow heads. I am running my same ole 230/230 baby cam.
I can not say enough about the quality and performance of the Trick Flow heads. It has been a pleasure dealing with Brian and Mike at TEA.
With the addition of the Trick Flow heads and FAST intake I improved my ET by over .4 in the ¼ mile and by almost .2 in the 1/8 mile.
Driving around town neither you nor the driver next to you would never think you are driving a 10 second car. Startup (cold and hot), idle, throttle response, and overall drivability are excellent even in the 90-100 degree temps we have had in Montgomery lately.
Setup details are in the signature. All runs are made with the car setup just as I drive it with the exception of the skinnies and ET Street Drag Radials mounted on Centerline Convo Pro wheels. Race weight was about 3420.
My goal was to run 10s on the motor in the summer heat. I need to set a new goal!
I feel sure the car will go 10.75 or better in negative DA weather conditions.
DA = 1915
60'------1.51
1/8------6.97
MPH----97.93
1/4------10.98
MPH----122.26
DA = 1764
60'------1.51
1/8------6.96
MPH----98.01
1/4------10.97
MPH----122.11
John
DA = 1915
60'------1.51
1/8------6.97
MPH----97.93
1/4------10.98
MPH----122.26
DA = 1764
60'------1.51
1/8------6.96
MPH----98.01
1/4------10.97
MPH----122.11
John
LS1 Tech Administrator
Very impressive ET and mph. The heads have really brought up your power. 122 mph with a 3420 race weight is BIG power, especially at that DA. When cool weather roll around, you'll be DEEP in the 10s. Congrats on the new gains!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Nice one. Congrats
What is you setup making power wise?
I'm hoping to be in the 10's NA myself in Sept.
BTW, is there a gadget available that can measure DA (something affordable)
Congrats on your great results, John. Do your Trickflow heads have the out- of- the- box finish, i.e., 64cc chambers, and stock TEA cnc? Just asking, 'cause the UPS guy delivers mine next Weds., and mine were milled to 61cc.
Moderator
Thanks guys.
Predator-Z – To measure DA I go to www.weatherunderground and get the conditions at the time of my run and then go to http://wahiduddin.net/calc/calc_da.htm and plug in the numbers.
You can buy a device such as http://store.summitracing.com/partde...5&autoview=sku that will do it for you at the track.
I do not know how much RWHP the setup is putting down. I do know that with my old setup I would run even with a buddy of mine that had almost the exact setup and put down ~425 RWHP through a locked 4L60E.
With the above as a ruler I would guess that the current setup is putting down some where between 425 and 450 RWHP with the converter locked
Louis – I have not heard or seen you post in a long time. How are you? Also thanks for a great cam!
Hennytime – You are right. I should have said “a baby cam by today’s standards”
exSSer – My heads are out of the box Trick Flow heads milled to 61cc chambers. You are going to love the heads!
John
John
Moderator
Originally Posted by TJ
any flow #'s on the heads. what tranny and gear.
times look SWEET!
times look SWEET!
I am running a 4L60E transmission and 3.73 gears in the stock rear.
I only have the Trick Flow flow data.
Lift-------------------- Intake-----------------Exhaust
0.100------------------- 68---------------------- 55
0.200------------------ 142 --------------------115
0.300------------------ 215-------------------- 185
0.400-------------------260-------------------- 230
0.500-------------------300-------------------- 251
0.600------------------ 320-------------------- 259
Originally Posted by JNorris
Thanks Bruce and JZ.
Great numbers.
Bill
