Post H/C Sewing Machine Sound
I just installed AFR heads @ 62cc and a 224.228 cam and there is a noticable "sewing machine sound" coming from the Valve Trane. My tuner told me to expect this and that it's common. My question is what exactly makes this sound. I have heard theries that it is due to incorrect geometry, spring pressure, valve closing etc.
Can someone explain exactly what's going on here. Valve wipe on this engine was checked dead on the center of the valve and push rod length was measured and confirmed correct so I don't think geometry is an issue here.
Originally Posted by AJay
Trick Flow Moly push rods
Rollmaster dual roller chain
Morel lifters
PRC dual springs (basic to the AFR Heads)
Stock GM Gaskets
Morel lifters
Stock GM Gaskets
You're in luck, Mr Viper runs the Morels, he can help you out.
My car bone stock had some sewing machine noise.... I wouldnt worry about it. It got slightly louder when I went to the PRC dual equipped LS6 heads. With more spring comes more noise. It shouldnt be ALOT louder than stock however.....
Going back to my original reason for this thread,,,,,, what exactly is making this noise. Is it increased spring pressure slamming the valves down harder on the seats?
Mine is significantly louder. Not too bad standing outside of the car with the hood up but inside the car it is very noticeable.
Even with proper predoad it WILL BE louder than stock. The ramp rates of the cam and stronger springs both contribute. You are opening and closing the valves much quicker than stock. Ask your installer where he set the preload. If it has been measured and is in spec, you are fine.
I wish I could say what EXACTLY causes the noise. All I can say is on my setup 7.325 pushrods were too much preload thus causing the ticking. I'm at 7.300 now ( after using a $20 pushrod checker ) with my preload around .025-.030 on the Morels and it's plenty quiet now. And FWIW, the 7.325 were put in by an engine builder! So nothing wrong with checking it yourself, or at least find out if the engine builder is aware of the required preload on the Morel lifters.
Could I be damaging my engine by running it this way?
Now understand we are not sure you are hacing preload issues until you pull the valve covers and actually measure, BUT, once you do:
https://ls1tech.com/forums/showthrea...t=preload+tick
https://ls1tech.com/forums/showthrea...hlight=preload
Fascinating read:
http://www.cranecams.com/?show=techarticle&id=2
Fascinating read:
Originally Posted by PREDATOR-Z
Too short of a p-rod
This valvetrain noise being acceptable is a misconception (which I believed for awhile).
Improper preload does that.(too light)
AJ- Its a typical sound for all heads and cam. youll be fine
Originally Posted by eamador11
I disagree, the cam he has is a fast ramp rate cam and the sewing machine sound comes from the valves slapping shut hard. The patriot springs also add to the sound due to the stiff coil but they are strong *** springs!
Take my new built 370, XE-R 232/234 .595/.598, Platinum PRC duals (~.660 lifts), 11.7 SCR, 8.6 DCR (high cylinder pressures).
Can't hear a peep out of the valvetrain. I use Comp 850-16 with .080 preload.
The valvetrain noise is nothing like I used to hear on earlier setups.
I started reducing noise by increasing preload closer to stock specs. The closer you get, the less noise.
Anyways this is from personal experience.
