Post-cammed ls1 startup, this normal?
Just curious...but my car idles high ( 1300RPM ) on startups until it warms up a little bit. Is this a normal thing ? It never did it until after the cam swap is the reason this is in the internal engine section. Just curious, thanks in advance.
have you had your car tuned yet for the new cam? if not that would most likely cause strang idle behavior?
Edit...i just read your sig...probably is a problem in your tune....my car idles a bit higher when i first start it up, but goes back down after a minute or 2... but it's not that high...maybe 1,000rpm at most
