need turbo cam recommendations
Old 07-12-2006, 08:58 AM
11 Second Truck Club
L-EATER's Avatar
Default need turbo cam recommendations
I am putting a STS turbo kit on my 6 liter. The turbo is a GT67 which I am told is good for about 750 crankshaft hp. Obviously I want to squeeze as much power as I can out of this combo. I have a set of stage 2 heads from ET Performance, and I need a cam recommendation. I really would like to stick with a smooth idle/gas mileage friendly cam. I am thinking LS6 but which one would work best with a turbo....the 2001, or the newer ones?
Are there any other off the shelf cams that would work well with the turbo? TIA.
Old 07-12-2006, 08:58 PM
CamKing's Avatar
For a turbo application you need a single pattern cam on 112-114
Old 07-14-2006, 05:30 PM
pwrtrip75's Avatar
go look in the forced induction section, from what ive read the 02-up LS6 cam is pretty good.
Old 07-14-2006, 06:02 PM
trtturbo's Avatar
The LS6 cam will work fine. If you use it, I would get the '02 and up.
You may also think about something a little bigger; 228/228 on a 114.
Old 07-14-2006, 06:07 PM
ThaLS1KidII's Avatar
PM sent...
Old 07-15-2006, 09:06 AM
4mula's Avatar
Old 07-15-2006, 10:27 AM
PREDATOR-Z's Avatar
225/225, 113+1 Lsa
