Hex key broken off in ARP stud...
I've got a small situation here and was wondering if anyone has some effective ideas as to how I can get out of it. I have an ARP head stud (small ones) that has a piece of a hex key stuck inside of it. From what I can tell, it broke off while being tightened down due to not using the correct size hex key (using a smaller key). The piece is almost flush with the stud and I'm just sitting here wondering how I'm going to get this thing out. Any ideas are welcome. I took a few pics, but my camera didn't focus in on the stud head since it's so small.
try 2 small pics and twist the broken piece in the opposite direction.
another idea is to find a small punch and try to dislodge the broken piece.
either way, place some rags around the stud, this way if a piece comes off and you don't see it, it will be caught with the rag.
I've seen this happen before and it just took a magnet to get it out. The piece just broke off, lost its tension, and was sitting in the top of the bolt. It might work for you too.
Otherwise, you have to use a pick, punch, or drill it out. Depending on how 'stuck' it is.
Originally Posted by calongo_SS
The real question is why were you tightening hard enought to break it?
Thanks for the help so far guys, it seems to be lodged in there so a magnet won't be enough to pull it out (I've already tried). This stud also is not installed in my block, I have it sitting here on my desk. I also was not the one who broke this piece off in the stud, I bought a set of ARP head studs from a member here and this is how it arrived. I'm hoping I can somehow take this piece out, seeing as how I was not informed that this stud was in this condition, I'm not a happy camper. Anymore input is welcome.
