TSP LS6 Stage 1 heads
Site says they flow 300-305 on the intake at .600
I had them flowed independantly after i got the
318cfm @ .600 lift
Cant wait to get them on the car with the MS4 sitting on the tool box.
Josh
318cfm @ .600 lift
Josh
what is it at all the other lift ranges? .100, .200, .300 ect. i would rather have higher #'s at all the others then just high #'s at .600. because you hit everything below you peak lift twice every time the valve opens. it would make more sense to me. post up the rest i am interested in it. thanks
nick
nick
Originally Posted by charlie c5
What are TSP LS6 heads, where can you get them, and how much do they cost?
with the valve job. I dint get complete flow numbers. A friend just too the head to the mach. shop. A bi name on the board but i will keep them nameless.
The rest of the flow numbers were good for a ported head but it was just the .600 lift that supprised me.
Also the cam will hit over .600 lift twice also since it's lift is .651/.611.
Josh
Josh
318cfm @ .600 lift
Josh
318cfm @ .600 lift
Josh
what size valves?
When you go to TSP's web site they show two different LS6 head pachages. An LS6 stage 1 and an LS6 stage 2.5. What's the difference, there is a $500.00 difference.
318cfm @ .600 lift
Josh
318cfm @ .600 lift
Josh
how long did it take for you to receive your heads from them?
