Cam & Heads & stall selection.
My car is a street/strip nitrous car I now have 3.73s but as the heading says I want to select H/C & stall next also I am curently looking for a 383 stroker kit to put together with this package so can you guys help me with selection of a powerful H/C thats nitrous and stroker friendly and still be ok for the street & please help me select a stall to go with this combo.What I am trying to do is have a car thats in the 10s NA and late 9s on the bottle .
You want to keep a fairly low stall, because it will stall higher with more power, and respond better on spray. The cam is perfect for a stroker and will create an awesome power band, and I don't need to explain the AFR's.
Thank you thank you thank you What else do you suggest 1.8 rocker arms perhaps?And what kind of power will this combo make?And what rpm will I be able to rev up to 6600?
They like to keep there cam specs secret. I wouldnt buy a cam with out knowing them, but with a little time searching on this board you will find them... If i remember correctly G5X series cams are gound on a comp X-ER lobe, but i dont remember the specs... i do know that the g5x4 is not much bigger than the g5x3... I think its like 2 degrees more duration on the intake and exhaust thats it... Also how big of a shot do you plan on running? Because below 200 shot cam selection wont be that big of a deal
Fly cut is a relief (a notch) in each piston so that there is no contact between the piston and the valves. When the valves open, they lower into the cylinder, coming closer to the top of the piston. This is bad...very bad.
if your goin to build a stroker engine at the same time as the rest of the mods, then you wont have to worry about flycuting the pistons. Im pretty sure good pistons will come with a oversized relief in them already, wont they? I know my stroker pistons (LT1 383) are dished AND have big reiliefs in there.
Im curious what you guys think would be a good rotating assembly for his LS1 engine that can handle 9s on spray.
