Stock LS1 combustion chamber
tech memeber
I've been reading on here that to maintain the stock compression ratio replacement heads should have a 65cc combustion chamber. But for the stock 10.1:1 compression ratio I calculated they should have a 77.88cc combustion chamber, and a 65cc combustion chamber would up the compression to 11.9:1. If someone could clarify for me why I'm calculating this incorrectly it would be greatly appreciated.
tech memeber
Okay, thanks for the info. But even with those numbers I get a combustion chamber of 68.645cc, or if it is a 66.667cc stock combustion chamber than a set of 65cc heads would increase the compression ratio correct?
