priming motor????
priming motor????
before starting up a new motor how do you prime it with these motors?
the old motor you could just hook a drill to the distributor and spin it up but thats no longer an option
thanks for the input
Originally Posted by nvmy2000ss
When I did mine I pulled the plug wires off the coils, Then turned the motor over until I saw oil pressure. May take a few times but you should see it eventually.
I hope you pulled the fuel pump fuse, too!
