oil pressure guage twitch???
00 t/a a4... my oil pressure gauge needle twitches back and forth at idle-- is this normal or is somthing about to go wrong ? what should i do to fix it??
The best thing to do would to get a mechanical gauge and check the oil pressure that way. It is the ONLY and most accurate way to accuratly check on your oil pressure. You have to drill and tap a hole for the Oil Presure Sending unit right above the oil filter. Use the search and there will be more detailed instructions.
