Need Help ..
Need Help ..
hi every one ,,
this is a small story but it makes you understand my case
i am from saudi arabia. i have Lumina Coupe SS (it is loke like GTO ) LS1 engine 5.7 as every body know.
i already add a K&n filter( complete intake ) , pully , complete exhaust system ( headers , X-pip , magnaflow ) ...
now i am adding a good heads ( patreiot stage 2 , 64 ( Dimond piston Rings... Federal Mogul connecting Rod Bearings.. ARP Connecting Rod Bolts .. Stock Pistons...notched and ready for BIG cams...(about 2cc VR)) ) and a G5x3(2xx /2xx , 0.6/0.61 114) camshaft
my problem is about tuning all these stuff , we have a problem in tuning our car well , no one can give you te best and smothest of your car !!
these are my quis :
so for all what i mentioned before what should i get in term of HP and tourqe in dyno ??. should i cahnge the lifters with this cam ? , and for tuning,is there any sulotion for my case ?
these are my quis :
In your case, if there are not local tuners, you might be better off getting a mail order tune. The other option would be tuning software like HPTuners or EFILive, but they you need to learn how to tune it yourself. Not a bad thing, but time consuming.
Are you doing your own installation? If not, does the installer have any tuning ability?
Also, one other thought, since you are getting a cam from LG, you might contact them about the tune, they might be able to get close with their experience with that cam. You could remove the PCM, ship it to them, and then let them program and ship back to you.
