Rod knock
Originally Posted by Caribe
You have a soundclip? Did it sound like this?
http://media.putfile.com/LS1-knocking
I will let you know what mine ends up being in a couple of days. Same thing oil pressure was fine. No metal in the oil. Springs and rockers were all good. I started the car and I heard a faint tapping which was different. When there was a slight load on the engine it began knocking like the video.
Good luck
Good luck
Whoa. My car's doing almost the exact same thing. I haven't checked all my pushrods but will tomorrow. Along with the oil and taking a look under the intake manifold. Mine's the driver's side too.
You might need some guide plates for the push rods after killing the drilled guide. Not too sure though. Get hardened pushrods to replace the stockers so you can rev it higher next time without bending a rod.
