What springs to go with XFI (.600" lift) Lobes?
What valve-springs would you recommend to go with to properly complement a Comp-Cam w/ XFI lobes, producing lifts (w/ 1.7 rocker) of .590"/.600"? Cam is a 214/218, going in a DD. I am only going to rev to ~6200 RPM. Heads are AFR205s, and I am using the STOCK LIFTERS. Thus, the gonzo stiff springs (ie, PRC-Duals) are going to be waaay too much for the stock lifters to handle longterm, and I'm not going to swap to Comp-Rs.
So, with the stock lifters, revving to ~6200rpm, XFI lobes (.600" lift).... Would Comp 918s work? Manley -1428s? AFR-8017s?
Whatever spring is recommended, I will be using Ti Retainers.
Thanks!
Thanks!
These are the springs that come on the Dart Pro 1's for LSx's. A friend of mine found this information and sent me the link. (Thanks vettenuts ) The spring information can be found in the link below, the PSI springs are part # PSILS1511, on page 18. The PSI information starts on page 17. These are a premium beehive spring and are marketed as Isky Toolroom springs. Give it a minute to load or it'll lock up on you.
http://www.cvproducts.com/cv/catalog/catalogs/M-P.pdf
I have been using as set of PRC platnum dual springs on a 233\233 .595\.595 lift 112 LSA cam for 31,000 miles without any problems.. using stock lifters..the lifters have 118,000+ miles on them now..stock lifters are strong sir....contact Tesas Speed & Performance ..
Observation - wouldn't a cam with high lift for that short duration warrant a dual spring like the Patriot Golds the AFR205 heads come with out of the box? I ran a custom cam 216/200 with ~.590 lift.
What valve spring preasures is Comp requiring for the cam?
Collapsing stock lifters with the heavier-duty dual PRC/PP/AFR springs seems to be pretty well documented on here (ie, much more common than on other springs). It appears the spring open-pressures are just too much for the stock lifters to handle with any amount of confidence. Hence, since I'm not going to be running a cam with lifts anywhere near the .650" maxlift rating of the PRC/PP dual springs, IMHO its overkill (and detrimental to the stock lifters). Figure there's a more friendly spring choice that will suit my application & provide (likely) better longevity and reliability.
Vettenuts has done a bunch of legwork looking into the stock lifters' capabilities to withstand greater spring pressures. Doesn't look too reliable from his postings....
Originally Posted by 02RedHawk
Collapsing stock lifters with the heavier-duty dual PRC/PP/AFR springs is pretty well documented on here. It appears the spring open-pressures are just too much for the stock lifters to handle with any amount of confidence. Hence, since I'm not going to be running a cam with lifts anywhere near the .660" maxlift rating of the PRC/PP dual springs, IMHO its overkill (and detrimental to the stock lifters). Figure there's a more friendly spring choice that will suit my application & provide (likely) better longevity and reliability.
I am pretty happy with the 31,000+ mile life span (and still growing every day) of my PRC dual springs. I am getting ready to do another cam and head swap and will use the Comp 921s this time with a higher lift cam. (LSX lobe) I look for a long life on those springs too. I Will replace the 118,000+ mile stock lifters at that time. My car sees the red line daily..no problems with it ... my car gets started and warmed up every morning for 5 minutes before I take off for the day..I think that is one reason that I have no oil consumption and long valve spring life.. the car is a daily driver ..
