Push rod weight difference?
Originally Posted by Phil99vette
Pushrod weight is not as important as strength.
I agree strength is important, but I want them the same weight or lighter. Valve train component weight matters. There are hollow valve stems for a reason.
7 Second Club
Originally Posted by 02WSsicks
From a performance standpoint???
The tradeoff is weight vs. deflection and the bigger issue is deflection. You want a stiffer pushrod even though there is a slight weight penalty. Since it is on the lifter side of the system and doesn't accelerate as mush as the valve side due to the rocker ratio, the weight penalty is not as big an issue. Bottom line, if the system is correctly setup, the pushrod weight won't matter that much, especially as comparted to the valve.
I agree with the above posts. Don't worry about the pushrod weight. Get the strongest one you can afford. You do not want flex in a pushrod. Remember it transfers the cam lobe profile to the valve. Me I'm going with the Terry Manton 3/8" thickwall pushrods in my SBC.
