What are some of the aftermarket parts it would be cool to see installed and tested?
LS1Tech Co-Founder
Hi guys, we've obviously been discussing mainstream LSx performance parts for a long time but I know there are other parts out there I don't see discussed as much or tested.... What comes to mind? Here are some things that I think of...
1) Aftermarket oil pans
2) Harrop 8 TB setup (looks so cool)
3) Girdles
4) Dry sump
How about you guys??????????????
3) Girdles
4) Dry sump
aftermarket oil pan would be pointless... dry sump in conjunction with the pan would be cool so see the gains. the harrop would be interesting to know the results, but its kinda way unrealistic for the vast majority of us. i would be more interested in seeing tests that would determine failing points of certain internal motor parts, maybe which sets of aftermarket rockers/lifters have best performance etc etc. maybe the et 245 head with a properly built motor, not just a stock shortblock with those heads ya know...
Definitely the Harrop is a front runner. Dying to see how much gain it offers over the LS7...with heads that flow like LS7 heads can. We know the LS7 heads are held back by the LS7 intake, so until a better head is built the LS7 heads will never perform to their max.
UNDER PRESSURE MOD
I'll agree with the quench vs. compression testing. Same heads, cam, headers etc, but one test with factory 0.056" gaskets, then swap them with a set of Cometic 0.040" gaskets, tune if necessary, and see what the difference is.
This could be a big deal if the results were on the order of 10-15 hp for the price of a set of gaskets, but isn't worth the time, money and hassle if it only nets 1-2hp.
