Anybody know the base circle on this cam?
Old 09-25-2006, 06:55 PM
mvvette97's Avatar
Default Anybody know the base circle on this cam?
It's a Comp XR228/230 571/573 112 LSA comp pt# 54-428-11 I am wanting to find this out so I can order the correct pushrods at the same time I order the cam and springs. Also what is the base circle on the stock 2000 cam?
Old 09-25-2006, 07:00 PM
redtail2426's Avatar
give me a few minutes i have it somewhere,written down.
Old 09-25-2006, 07:02 PM
mvvette97's Avatar
Thanks
Old 09-25-2006, 07:06 PM
okay the stock cam radius is .775" and diameter is 1.550 ..
comp 228/230 radius is .732" and diameter is 1.463
I am using a 7.4 pushrod with a .045 cometic head gasket and heads milled .018..If using stock heads and stock head gaskets then use 7.425" pushrods
Old 09-25-2006, 08:09 PM
oange ss's Avatar
LS1Tech 10 Year
holy ****, now that's service !
Old 09-25-2006, 08:24 PM
mvvette97's Avatar
That's great info. Thanks alot for checking for me
Old 09-26-2006, 12:01 AM
PREDATOR-Z's Avatar
Yeah that is a XE lobe. I agree with 7.425 on cam only swap.
Old 09-26-2006, 12:10 AM
mvvette97's Avatar
do i have this correct? The cam I am getting is XR281HR pt#54-428-11, so this is NOT the same as the XER281HR is it because the XER cam has more lift? Call me stupid but i see alot of people talk about the XE lobe and the XER but the cam I'm going to get is the XR. What is the differance? Too many Xs and Es and Rs get me confused
Old 09-26-2006, 07:46 PM
just ignore the Xr in the part number,it is an XE lobe design.The Xe-r are the ones with more lift and more aggressive ramp rate.
Old 09-27-2006, 07:26 AM
ISeeRed's Avatar
2000 base circle (radius) is 19.7 mm (double if if you're gonna measure it with calipers) 01 ls6 is 19.3mm and 02+ is 19.0mm. The valves on 02+ are .6mm longer to compensate for smaller base circle (that's .02366" so 7.425" pushrods are right if it's similar to ls6 base circle....)
Old 04-11-2007, 05:37 PM
1CAMWNDR's Avatar
I am about to get a Comp XE cam also. I have 7.4" pushrods on my stock heads and cam. I am going to have the heads milled to a 62cc chamber and use a .040" headgasket. Best I can figure I will still be good with the 7.4" pushrods. Anyone agree or disagree?
Old 04-11-2007, 05:39 PM
brad8266's Avatar
Get a pushrod checking tool and measure what you need, dont bother guessing.
My XE cam lobes measured in at 1.450 with a dial caliper.
Old 04-11-2007, 05:49 PM
1CAMWNDR's Avatar
Thanks. I might do that, but the pushrod calculator says 7.38" pushrod for a base circle of 1.463 or 1.50. I think 7.4 is a go.
Quick Reply: Anybody know the base circle on this cam?
