Is re-torquing required on aftermarket head gaskets?
Considering Felpro of Cometic head gaskets in range of .040 to .045. Anyone know if they need to be re-torqued? If so, how many times?
I installed felpro's #1041 gaskets and they began to seep. Called felpro and was told they needed re-torqued TWICE after heat cycling, for a total of 3 torqueings. By comparison, SCE copper gaskets only need retorqued once. I had wrongly assumed the felpro's were permatorque style and didnt need retorqueing at all. Felpro said all their performance gaskets need retorqued this way.
Installed my heads on Cometics (copper sprayed) using ARP studs w/oil for lube (not ARP lube). Torqued to the higher value as instructed by ARP when lubing w/oil. Re-torqed after a few heat cycles & none of the studs had changed. All of the studs retained their torque. This is not to say that re-torquing isn't required. I'd say back 'em off once or twice during initial install & re-torque @ least once after heat cycle.
As for GM stretch bolts, I always stretched 'em as instructed & let them be. Don't know that it's possible to re-torque.
