LQ9 vs LS1 in power output?
Old 10-31-2006, 09:47 AM
DogNutz's Avatar
Default LQ9 vs LS1 in power output?
Comparing the 2 engines and installing the same cam into the LQ9(317 heads) as you would the LS1 and throw a LS6 intake on the LQ9 same as you would the LS1 which engine will produce more power? Both having the basic bolt on supporting mods, ie: headers, ported throttle body, Lid. Is it also worth the swap into an F-body for the power gain assuming their is one?
EDIT: Found out the engine is an LQ4!
Old 10-31-2006, 10:23 AM
treyZ28's Avatar
LQ9 for sure. Nearly identical compression, but the LQ9 has a bigger bore, more displacement and better heads. Also aluminum blocks wick away a bit more power.
Lq9 is severely detuned from the factory since its in a heavy truck that has a 10,000lb tow rating. You dont want to overheat that engine under sustained load.
edit: Both the Lq9 and the Ls1 has 10.0:1 compression.
thats what a quick google search tells me anyway.
Old 10-31-2006, 10:33 AM
'JustDreamin''s Avatar
According to GM's website, Marine versions of the LQ4 are rated for 370 hp and the LQ9 is rated for 380. I've seen a few of the marinizers get a bit more out of them with exhaust manifolds (typically 5 to 20hp).
http://www.gm.com/automotive/gmpower...000_marine.pdf
I know this seems pretty un-related, but it just goes to show there is a fair bit more power there than GM may be advertising (or allowed to because of testing protocols & fairly conservative tunes).
'JustDreamin'
Old 10-31-2006, 01:01 PM
Need More N2O Mod
mwalls54's Avatar
lq9 would make more power for sure. the only down side is the weight difference.
Old 10-31-2006, 01:14 PM
treyZ28's Avatar
Depends on the vehicle. An RX7? No, I'd rather run an LsX. My truck? an LqX
Old 10-31-2006, 01:15 PM
DogNutz's Avatar
Found out that the engine is an LQ4 so i would be raising the compression to around 11.1 either with a head change or 408 stroker assembly so now my question is almost mute because that guarantees more power for sure.
Quick Reply: LQ9 vs LS1 in power output?
