Any reason not to run ported oil pump Vs. Stock ls6
I am going to replace my ls1 oil pump. The motor is stock. Is there a reason not to run a ported pump? I don't care about cost, I only want to do this once.
So are there any downsides to a ported pump?
BTW- I plan on road racing the car.
Originally Posted by N4cer
I'm running a TSP ported oil pump. Very good pressure and no problems whatsoever. I highly recommend it.
Ben T.
Of course. That wasn't my point. I guess I just assume that everyone knows better, but you're right - better make sure they understand. My point was that it is performing well and I'm not seeing any leaks or other issues. Porting should THEORETICALLY reduce pressure, although it would only be by a fraction of a PSI over the entire system.
Originally Posted by Studytime
No, it will not increase the volumetric flow rate either by porting the pump.
Ben T.
Ben T.
I'd like to see PSI, volume and hp tests done on ported vs stock pumps so we know if they're worth it or not.
Originally Posted by Billdog350
this makes sense since the gearators are still moving/displacing the same volume. All you're doing is making it easier for oil to get in and out.
As for is it an appreciable amount of power? Well, every little bit helps, right? After you add up enough 2s and 3s, you start to have an advantage over the next guy.
Ben T.
When you put one in inspect it carefully,
just tore down an engine where the porting had drilled through the body of the pump,3 times they welded it ( ) and then put it into the engine, no numbers or markings on the pump so not sure who did the work or which pump it was. it appears on magnification that there was a crack at the weld. likely opened up when the pump got hot and allowed some air into the body of the pump, REALLY easy to tell where the welds were.
