Milling Heads
Old 11-21-2006, 02:38 PM
Juiced's Avatar
Default Milling Heads
How much would I have to mill my heads to get a a minimum 14:1 compression ration.
64cc chamber
4.060 bore
3.750 stroke
7cc dome on pistons
.040 cometic gasket
Old 11-21-2006, 07:06 PM
JPH
JPH's Avatar
THRU MY CALCULATIONS, I FIGURED YOU HAD A GASKET BORE OF 4.100", and a -.010 deck height, and getting the chamber down to 61cc would get you actally 14:1. which would mean .006 usually per cc, so 64-61=3 and 3ccX.006=.018. .018-.020 should get you there. tell me your gasket bore size and deck height(how farpiston protrudes out of deck) and i will give you a more exact figure.
