98 motor, LS6 heads. What gaskets?
Old 11-21-2006, 11:06 PM
03BlackWidow's Avatar
Default 98 motor, LS6 heads. What gaskets?
About to put my 98 C5 back together but need to figure this out really quick.
I am putting on cnc'd LS6 heads, do i use head gaskets for a 98 or a different year?
I already have a set of stock 98 gm headgaskets and a set of fel pro mls headgaskets for a 98 w/ about 20 mintues of run time on them but have heard they wont work w/ the LS6 heads.
Old 11-22-2006, 10:16 AM
GuitsBoy's Avatar
you can use any gasket with the ls6 heads. Its the 98 heads (not the block) that has the detent that could cause a leak with newer style gaskets.
I would look into the GM MLS gaskets, either 5.7 or 6.0L will work. The 6.0L gaskets are advertised as a little thinner, but IMO theyre about the same compressed thickness.
Old 11-22-2006, 11:19 AM
SS4Matt's Avatar
i have a '98 SS and i'm running patriot's LS6 heads with the MLS 6.0 Gasket. i've been running them for well over a year with absolutly no problems
Old 11-22-2006, 05:27 PM
Alright just to clear it up. I can use any year LS1 gaskets (including 98) w/ LS6 heads and have no problems. But if i use 98 heads then i can only use 98 gaskets. Correct?
Old 11-23-2006, 01:11 PM
bump!
Old 11-23-2006, 01:15 PM
Mssingkid's Avatar
Correct!! I'm running LS6 heads with Cometic .045 gaskets...
